vin decoding neeeded
Old Mar 7, 2005 | 07:38 PM
frog1326's Avatar
frog1326
Talking vin decoding neeeded
I am new to this site and have found it most informative I have a 62 unibody and I am starting a rebuild. I would like to know as much as possible about it. the numbers are as follows:serial/vin#f10jn21, color:114b, tran:a, axle 12, hp:114@3600. I was told it came with a 292 but find this hard to believe since there was a 6 cyl in it when I got it. I pulled out the 6 and thanks to concours for supplying me with a great new crossmember Im putting in a 400 that i got in a 65 for parts.
Old Mar 7, 2005 | 07:45 PM
61ford's Avatar
61ford
according to lmc your truck originally came with a 223 but couldnt find anything bout original color or anything else
Old Mar 8, 2005 | 10:10 AM
Mike G's Avatar
Mike G
Sorry you got some bad initial info, was it from this board? here is something more to ponder:
F10 = F100
J = 223 I6 1v carb 114hp@3600 rpm
N = Norfolk assembly
21xxx = September 61 build sequence
114 = wb (shortbed I think)
B = Turquoise (sort of greenish)
A = 3 speed tranny
Axle 12 = 3:89 gears
See if that helps... --Mike
Old Mar 8, 2005 | 10:58 AM
frog1326's Avatar
frog1326
thanks mike it is a shortbed unibody
ChrisZX2
Projects
Sep 14, 2011 01:46 PM
my64f100
Jun 30, 2010 10:46 PM
harold4039
Apr 24, 2009 06:46 AM
Daviddc114
May 27, 2008 10:42 PM
banjopicker66
May 2, 2004 07:41 AM
