Serious Clutch Problems
Old Mar 7, 2005 | 05:58 PM
Bronco2Nic's Avatar
Bronco2Nic
Hey, I have a big problem with my clutch. When I bought the truck, the engine was toasted so I put in another 2.8L. I only put in a new clutch disk and everything else seemed to look alright. It all worked fine but now when my clutch is engaged (pedal up) It makes a squeaking sound like the clutch is slipping, and when I push the pedal down it makes a scratching sound like the clutch is not releasing fully. I looked under my truck and there is a gray looking fluid around where the bellhousing bolts to the block. Could my slave-cylinder be leaking. Help please.
