4.2 Auto
Old Mar 7, 2005 | 08:15 AM
Inda Bonda's Avatar
Inda Bonda
4.2 Auto
I'm wondering why the automatics' shift points are so low. Mine usually shifts between 17k - 25k rpms. That's normal driving. I'll sometimes shift it to 2nd gear and I can go 55mph w/o any trouble. I think it hovers around 42k rpms. Something like that.
Would a super tuner move the shift points?
Old Mar 7, 2005 | 09:45 AM
horizonhuskies's Avatar
horizonhuskies
42,000 rpms?? Holy crap! Mine only does 5400 RPM redline. You should be running low 7's with that kinda powerband
Any how, do you drive with OD on? In my M5OD, I can do 57 in 2nd, then shift to hit third, without losing my powerband, so I would imagine that 55 in an AUTO is ok. Yes, a tuner can change your shift points, but please please becareful of changes like that. Ive heard of some problems arising, but we all know every tuner is perfect, and can do anything you want.....
Good luck.
Garrett
Old Mar 7, 2005 | 09:49 AM
true4.2's Avatar
true4.2
Garrett, you took the words from my mouth!
Old Mar 7, 2005 | 11:01 AM
BrianA's Avatar
BrianA
I noticed that real quick after getting the '05 w/ auto as compared to the '00 w/ 5 speed.
I'm quite sure the shift points are set to improve mpg numbers. The lower you keep the rpms, the better the mpg. Performance is sacrificed on the alter of fuel economy. I wish they had a switch so you could select "performance" or "economy".
Often around town, I'll just turn OD off.
I'm already figuring that after warranty, I'll either get a chip, or a tuner, so I can alter the shift points.
FWIW, the mpg numbers are about the same comparing the '05 to the '00.
Old Mar 7, 2005 | 07:59 PM
homer4.2's Avatar
homer4.2
Brian-Do you have any pictures of your new truck yet??
Old Mar 7, 2005 | 11:07 PM
BrianA's Avatar
BrianA
sorry, not yet. I promise to try and get some this weekend.
Thanks for asking.
Old Mar 8, 2005 | 09:50 AM
Inda Bonda's Avatar
Inda Bonda
When turning the OD off, what does that actually do? I heard somone say that never turn the OD off except when you tow.
Old Mar 8, 2005 | 07:26 PM
homer4.2's Avatar
homer4.2
It just doesn't allow the truck to go into 5th gear. So you are workin with 4 gears instead of 5
Old Mar 10, 2005 | 02:04 AM
A_Fire_InsideR1's Avatar
A_Fire_InsideR1
i know thats supposed to be correct but i dont think so on our trucks. when i'm not in overdrive the rpms go sky high before my truck shifts.
Doc150
Jul 26, 2013 10:02 PM
Dallasee
Sep 2, 2011 05:29 PM
stf26
6.7L Power Stroke Diesel
Aug 1, 2010 09:53 PM
gumbydamit
Sep 27, 2006 08:53 PM
StorminTexan
3.8 & 4.2L V6
18
Aug 19, 2004 03:13 PM
