Need rear axle w/ 5x4.75 lugs
on
Originally Posted by brandontolentino
I have a 54 F-100 and need to swap in a rear axle to match the bolt pattern on the front end, which is a grafted on 67 Buick Skylark GS with the 4x4.75 bolt pattern. Anyone know any rear ends that would be close to a bolt on?
Thanks,
Brandon
Thanks,
Brandon
I know of no GM rear ends that would be a bolt on. In terms of width 67-69 Camaro/Firebird would be close as would 68-74 Nova and the Nova clones like Buick Apollo, Pontiac Ventura, and Olds Omega of the same years. These rears are 59-60 inches wide and you need 61. Also, 64-77 Chevelle might work but they are wider at 62-63 inches.
Vern
One thing to remember is if one of these will fit width wise you can always buy wheels with an offset that will work.
Originally Posted by GreatNorthWoods
Brandon,
Vern
Vern
on
I am not really worried about rotating wheels with the front. I will end up having a larger tire on the rear anyway. It's just hard to find nice rims (that I like) in the 5x5.5 bolt pattern. I want to make sure that I can have a spare tire too.....sounds like a dual pattern wheel would fit the billl. Now all I have to do is figure out how to convert my current axle to the smaller lug pattern....
on
Those type of wheels have a hubcap like stock but smooth. There are two ways of getting smaller bolt circle:
1) Keeping the stock Dana 44 rear axle. Have axles redrilled. Use backing plates of a '68-72 F-100 and drums off a 72-76 Torino or Ranchero with V-8.
or
2) swap in a Ford 9" from a '68-72 F-100. Use 2 driver side axles of a 72-76 Torino or Ranchero and drums also. The Ford 9" is a direct bolt in but requires a new u-bolt plate as the axle tubes is 3" wide instead of the stock 2.5".
If you want some more info check this out. What your looking for is about half way down.
https://www.ford-trucks.com/article/...ial_Swaps.html
or
DW SD
12-03-2014 09:00 AM
The Outlaw
02-04-2014 08:01 AM
