dead as a hammer
Old Jul 31, 2001 | 08:46 PM
rodsf250's Avatar
rodsf250
dead as a hammer
motor will not crank, no fire to starter, cannot even jump solenoid is ther a fuseable link in steering coloum? new battery just intermitter power on ignition wire on solenoid.
Old Jul 31, 2001 | 09:02 PM
jakegypsum's Avatar
jakegypsum
dead as a hammer
I would have to believe that if you can't jump at the solinoid, there is a bad connection at the battery. You should be able to jump the solinoid using the little post and the larger "hot" post. The starter should at least turn over. Perhaps the battery terminals and/or cables need to be replaced. Good luck. Jake.
Jakegypsum // Ford fleet, soup to nuts.
Old Aug 1, 2001 | 10:35 PM
quads's Avatar
quads
dead as a hammer
I would start with the battery also check for good ground..if thats not it then check the ignition switch make sure you have 12-13 volts coming to the battery. and then 12 volts going from Battery to solinoid and then from solkinoid to starter. Good Luck Godbless
Marc Conley
Morganton Nc
82 F-100
W/302
Old Aug 2, 2001 | 10:21 PM
taurus's Avatar
taurus
dead as a hammer
try your neutral safety switch
Robbie
Old Aug 3, 2001 | 04:56 AM
Fordtruxrok's Avatar
Fordtruxrok
dead as a hammer
