"yahoo" found problem with 10kmod
Old Mar 6, 2005 | 12:21 PM
jadel's Avatar
jadel
Thumbs up "yahoo" found problem with 10kmod
I have found my problem with my 10 k mod turns out my 10k was not a 10k but a 1k no wonder it was idleing so rough and throwing the check engine light good job it was on a switch or might of caused some damage i used the color chart on a website you guys provided you guys are great thanks for all your help this is agreat site.Now all i have to do is take the 1k out and install the 10k,can i install a5.6k my mods are shimmed the fpr,removed cat,napa 6637 filter mod please replythanks
Old Mar 6, 2005 | 12:42 PM
RedStroker6's Avatar
RedStroker6
yeah, my mods are about the same and i'm running the 5.6K i think i noticed a little more oomph, though it might have just been thinking things.
Old Mar 6, 2005 | 01:29 PM
Kwikkordead's Avatar
Kwikkordead
Jadel I recommend putting a switch on the 5.6k. Your idle will still be pretty rough and erratic. If I throw the switch on mine while idleing it will surge up and down between 600-1200 rpm, and shaking the whole time. Turn it off and it idles smooth as glass.
Old Mar 6, 2005 | 01:31 PM
RedStroker6
my idle isn't really that rough. perhaps i'll go out and re-stick it in the plug...it pretty much stays steady. maybe i'll go re-stick it right now....
Old Mar 6, 2005 | 01:36 PM
jadel's Avatar
jadel
thanks for your reply i have aswitch already installed but iam going to try the 10k first because i have never realy had the chance seeing that it was a 1k instesd of a10k resistor.
