Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
How Much Torque Can Sockets Handle?
Old Mar 9, 2005 | 10:21 AM
crecity678's Avatar
crecity678
regular sockets are hardened for longer life on day to day applications. impact sockets are not hardened giving them more flex instead of breaking. like the others said go with the thick wall quality sockets.
Old Mar 9, 2005 | 05:50 PM
Munkey's Avatar
Munkey
Superdave37076,
Lug nuts on my '02 F-250 call for 155lb/ft. Came straight from the factory service manual, thats where.
Old Mar 9, 2005 | 05:57 PM
Superdave37076's Avatar
Superdave37076
Okay, didn't notice you have a BIG truck. Yep, I'd get a 6 point deep impact socket. I also saw an article in "Circle Track Racing" about lug nuts. Seems they took a 1/2" extension and welded an offset handle to help you hold the wrench straight as you torque the lug nuts. The inspector's use them to test torques before you hit the track. I'll try to scan it and post it. It helps you hold the wrench straight as you torque.
SD
Old Mar 9, 2005 | 06:15 PM
sandrail's Avatar
sandrail
Why are you using a deep socket? If you use a standard 6 point socket you won't have near as much of a problem with breakage.
ak-angler
Modular V10 (6.8l)
302
Nov 25, 2023 02:39 AM
Encho
1978 - 1996 Big Bronco
42
Jun 5, 2021 04:42 PM
Encho
41
Mar 3, 2016 12:16 AM
lawdawg79
Garage & Workshop
Nov 24, 2015 05:34 PM
viperbluelx
Jul 8, 2007 04:54 PM
