Hello
I have some play in the steering on my e150. When i reach in the engine compartment and grab the knuckle above where it conects to the steering gear i can turn it back and forth with my hand which in turn turns the steering wheel is this normal it is difficult to steer on the interstate when going over 50ish but when under 50 or so it isnt that bad . Thanks in advance for any help
Mike 1992 e150
There is a adj. that you can do on the gear box to tighten up the steering....There is a nut on top with a screw going thru it ....Do a search on the forums to find out the right way to do it....Just search for steering gearbox adj.
