Sponsored by: Real Truck
Stalling when put in reverse???
Old Mar 5, 2005 | 07:52 PM
Bigham's Avatar
Bigham
Red face Stalling when put in reverse???
I was looking for a spare F250 gasser today and found a 1999 RC LB 150,000 miles but every time I put it in reverse the rpms would drop to 400 rpms and when it was in 4x4 it would stall out. It was up to opperating temp. I did not purchase this vehicle yet. I wanted to ask y'all what could be wrong before i get it. Hard to pass up for $8,500
Thanks for all your help.
Eddie
Old Mar 5, 2005 | 08:08 PM
high ho silver's Avatar
high ho silver
What does it do when put into forward or in gear with foot on brakes? Could be a bad IAC or a vacuum leak.
Old Mar 5, 2005 | 08:16 PM
Bigham's Avatar
Bigham
The rpms do not move when it is put in drive. it is only when put in reverse. What is an IAC?
Old Mar 5, 2005 | 08:18 PM
high ho silver
Idle Air Control valve.
Old Mar 6, 2005 | 08:37 AM
Casey's Avatar
Casey
It's either low on trans fluid or the internal trans filter isn't seated right. Line pressure is higher in reverse, so there is more load on the pump. If the pump doesn't get enough fluid the torque converter clutch will drag on. That will make it stall. If it gets REAL low on fluid it could do it in drive, too, but it will only do it in reverse first.
Old Mar 6, 2005 | 11:42 PM
Gregsd250's Avatar
Gregsd250
I agree with casey... My transmission droped down about a pint and it did exactly what your discribing. i put in the fluid and wala transmission like new again. hopfully thats all that is wrong with this one.. good luck
Old Mar 7, 2005 | 12:30 AM
wlihntr's Avatar
wlihntr
yepper, casey is right on. here is a link, you may have to cut and paste
http://www.intellidog.com/dieselmann/symptom.htm#tcc
Old Mar 7, 2005 | 07:25 AM
Bigham's Avatar
Bigham
Hey thanks guys for all your help. It is much appreaciated.
Eddie
Old Mar 7, 2005 | 08:03 AM
Tjdb2000's Avatar
Tjdb2000
Yep. Trans fluid is probably low. My truck was doing the same thing, and was a little low on fluid.
mxracer3276
Dec 28, 2010 04:03 PM
tbart16
Feb 1, 2010 11:31 AM
hon147
Oct 10, 2008 11:50 AM
jsphsol6
Nov 13, 2006 04:16 PM
xfordtech
Dec 8, 2005 09:27 AM
