Speed Odometer
Old Mar 5, 2005 | 03:09 PM
SmokeGray-F150's Avatar
SmokeGray-F150
Speed Odometer
Got a 02 HD F150. Having problems with my speed odometer? Mileage display is not clocking properly? Know of any way to fix or disconnect completely?
Thanks.
Old Mar 5, 2005 | 04:06 PM
captchas's Avatar
captchas
Guest
if you changed the tire size , it has to be reset for calabration
Old Mar 5, 2005 | 07:43 PM
SmokeGray-F150
Re-Calibration SpeedOdometer
Captchas,
Thanks. Can I disconnect it?
Old Mar 5, 2005 | 08:02 PM
captchas's Avatar
captchas
Guest
no the auto trans if you have one will not shift correctly and your abs will be the same. input to the speedo head is off the rear axle ring gear. its effected by tire size changes. your dealer or some one with a programer can reset the tire size input its not a major thing
Old Mar 9, 2005 | 01:03 PM
SmokeGray-F150
Thank you.
Old Mar 12, 2005 | 12:09 AM
mkoser's Avatar
mkoser
plus it is illegal to disconnect it.
mk
