fuel problems/won't start
Old Mar 5, 2005 | 10:25 AM
shipps8's Avatar
shipps8
1992 F150 300 6CYL A couple months ago, the front tank stopped working, the back tank had a leak, so we replaced the back tank and installed a new fuel pump. We've been running on the back tank since then. Now truck won't run on either tank. When I try to crank it the engine is spinning, but I'm not hearing the fuel pump prime up/whirling sound. I pulled codes 327-EVP circuit below min voltage, 332-Insufficient EGR flow detected and 542-Fuel Pump Secondary circuit failure-ground to PCM. What's wrong!! Will replacing the EGR replacement position sensor be enough, or do I have to replace the whole EGR Valve? How do I check the PCM ground? I have the Haynes book, but I'm still confused.
Old Mar 5, 2005 | 08:37 PM
LxMan1's Avatar
LxMan1
Welcome to the forum.
The pcm ground is usually attatched to the ground cable at the battery.
I would check the fuel pump relay too. It could be bad.
FordGuy90
16
Mar 28, 2014 09:19 AM
g_k50
1978 - 1996 Big Bronco
21
Oct 11, 2008 07:48 PM
themoparkid
Jul 20, 2008 12:36 PM
Mech 1990
1997 - 2003 F150
19
Dec 10, 2006 02:34 PM
mattklionsky
1997 - 2003 F150
Aug 2, 2001 11:00 PM
