Hard Starting
Old Aug 12, 2001 | 03:52 AM
Fordtruxrok's Avatar
Fordtruxrok
Hard Starting
I have an 86 F150 302 C6 eecIV 2wd 175,000. When the truck is cold the only way to start it is to floor it and crank it forever. If I give it no gas it acts like it's flooded, as in raw fuel spraying out the exhaust. When it's hot it fires right up. All new fuel filters, new external fuel pump. I'm not sure if the in tank pump is original. After I finally get it started it runs like a cold alky engine, sound like its not hitting all the cylinders pretty much just misses REALLY bad. Any ideas what is wrong??
John
Thanks for any help
Old Aug 12, 2001 | 07:13 PM
sledger's Avatar
sledger
Hard Starting
[font size="1" color="#FF0000"]LAST EDITED ON 12-Aug-01 AT 08:16 PM (EST)[/font][p]It sounds very similar to a problem I had several years ago with mine. It turned out to be the fuel pressure regulation valve. It's kinda hard to get to, but not that expensive or hard to replace.
Did you, by chance, notice worse than the normally bad gas mileage before this started?
Old Aug 13, 2001 | 09:28 AM
Fordtruxrok
Hard Starting
I pulled a lean signal code with my scanner, the high pressure pump went out and I replaced it. Ever since I replaced the pum my truck has semmed to run a little rich. As far as gas mileage, it's more like mile gasage. I'll test the regulator with a vac pump, and let you know what happens.
THANKS A WHOLE BUNCH
John
Old Aug 13, 2001 | 02:39 PM
AWGuinn's Avatar
AWGuinn
Hard Starting
You might also check the air bypass valve. They can get gummed up with carbon and cause problems with cold engines. Just pull it off and clean it with choke cleaner. That was my problem.
Old Aug 14, 2001 | 01:46 AM
Fordtruxrok
Hard Starting
I've already cleaned out the Iac.
John
Old Aug 15, 2001 | 04:23 AM
Fordtruxrok
Hard Starting
Regulator is bad, will change this weekend. BTW what is the max press. an oem regulator will run at?
John
Old Aug 15, 2001 | 01:29 PM
gimps's Avatar
gimps
Hard Starting
