Ford 7.3 engine mileage
Old Mar 4, 2005 | 07:11 PM
jboard's Avatar
jboard
Question Ford 7.3 engine mileage
Hi, how many miles is a 1990 F350 Navistar 7.3L diesel engine good for? And what things can I do to make the engine last as long as possible?
Jeremy
Old Mar 4, 2005 | 07:34 PM
GreatWhite's Avatar
GreatWhite
I have a 90 f350 7.3. I read (here on FTE i think) that you can get up to 400k on a IDI 7.3L before a major rebuild. But, like you, I'd sure be interested in what you can do to help make sure you get the most miles out of it before rebuilding. Good question!
Old Mar 4, 2005 | 07:36 PM
jboard's Avatar
jboard
GreatWhite thanks for the help.
Jeremy
Old Mar 4, 2005 | 09:31 PM
harleyjohn45's Avatar
harleyjohn45
i think you need luck, a good maintenance program, and most of all "don't run it wide open". the fellow who rebuilt my engine told me to hold it to 2200 rpm cruising and it will last indefinately. i take him at his word. 2200 rpm in 5th gear is 70 mph, 2200 rpm in 4th is 58 mph, and 2200 rpm in third 45 mph. when i hit the higher elevations i will just slow down. i have a gear that will make it to the top.
Old Mar 4, 2005 | 09:37 PM
cetane anyone ??'s Avatar
cetane anyone ??
Basic maint. such as fluids and filters are a must. You MUST maintain the SCA's to reduce the chance of cavitation. That will bring your engine life to an abrupt end. 7.3's are esp. prone to cavitation.
The coolent additives are avail. at ford and IH.
There are lots of threads here on performance. Doing a search on this forum will bring you a ton of info. One of the most simple and cheap is to cut the "fish bowl" and the deflector out from under your air cleaner lid for better air flow.
Run motorcraft glow plugs.
Don't crank on your starter for more than 15-20 sec. at a time & Let it cool for about a minute or two each time. They can burn out easily. They only cost $600 new!!
Good Luck. Enjoy. They are fun most of the time.
Old Mar 4, 2005 | 09:46 PM
harleyjohn45
i've done the soup bowl and cold air induction. i've done the large exhaust and just about everything the forum has suggested. i have not made any changes to the injector pump or propane hop up kits. i would like a turbo, but i worry if the idi will handle the increased pressures. i've added the sca's, but have not bought test strips. the sca's were just added to a rebuilt engine this week. the directions said they should be tested once a year or if fluids have been added. the small container of napakool was not big enough, so i bought the quart size and put in the right amount. i really do listen to people on this forum, because i have really learned about this truck here.
Old Mar 4, 2005 | 09:49 PM
soulpatchfr's Avatar
soulpatchfr
400k + is not unheard of or out of the ordinary. i'm at 233k & running strong.
make her last... hmmm...
synthetic oil. bypass oil filtration system. clean air, fuel & oil fiters. don't forget the CDR. fuel lube/conditioner in every tank. SCAs (supplemental coolant additives) and a coolant filter. good (read accurate, aftermarket) gauges so you can see what's REALLY going on.
learn which parts NOT to replace with aftermarket ones: thermostat, glowplugs, any others?
that ought keep you busy for a little while
Old Mar 4, 2005 | 09:51 PM
soulpatchfr
harley - i have some extra napa test strips... PM me an address, & i'll send you a set of 4.
Old Mar 4, 2005 | 09:59 PM
harleyjohn45
soulpatchfr, you are a gentleman. thank you
Old Mar 5, 2005 | 07:55 AM
GreatWhite's Avatar
GreatWhite
I'm new to the diesel world. Recently purchased a 90 f350 7.3 auto CC dually. Changed fluids in it within a couple weeks of getting it, before I found FTE or knew about sca's and cavitation. So, i have a couple of questions:
1. Since it now has new coolant in it, do I still need a sca?
2. Any way to test for cavitation issues that have already happened prior to me owning it?
Thanks guys!
Old Mar 5, 2005 | 05:00 PM
cetane anyone ??
1. You can get the coolent test strips at NAPA, FORD, IH dealers.
2. Tougher question. It would be nice if you had a written record of the sca's by the previous owner. Most of us are not that lucky. There is not a way to retro check sca's from years gone by.
I don't know of an exact way to measure cyl wall thickness while the engine is intact. When they are apart, you can magnaflux and possibly sonic test them (someone correct me if I am wrong on that, thanks). Meanwhile you have to monitor them for fluids mixing in the wrong places. Coolent in the oil. Oil in the coolent. White smoke while driving/and having your foot in it. There should be a little black smoke. There might be some different opinions out there. These symptoms can indicate cavitation, oil cooler trouble, blown head gaskets,etc. depending.....
Can be tough to ID the problem sometimes.
Old Mar 5, 2005 | 07:13 PM
soulpatchfr
1. YES. you can buy it in bottles from napa & add enough (but not too much) to keep the SCA levels where they should be - you know that by using the test strips. next coolant change, i'm flushing & switching over to fleetgaurd (available at IH or your local Ford stealership). different properties, so they do not play well together, hence the flush. i understand it's a little better - newer technology. & i won't have to buy 50 test strips at a time like at napa.
2. not that i know of, but to expand on cetane's post - you could have your oil analyzed & find out exactly what's in that oil (coolant, for one thing) - a good lab (Blackstone is who i use) will be able to tell you more than you probably want to know.
3. BONUS ROUND! you have good taste, mr. shark... ford makes it, international shakes it.
Old Mar 5, 2005 | 07:28 PM
soulpatchfr
sorry for unrelated junk post, guys...
John, i tried replying to your email last night with a few comments - it bounced back, don't think you got it. can't EM or PM you thru TFE - send me a good email addy.
Old Mar 8, 2005 | 07:10 PM
2Fords1Jeep's Avatar
2Fords1Jeep
I don't know where you buy your parts, but I bought a starter for my '89 7.3 at NAPA for $160.00.
Old Mar 8, 2005 | 07:26 PM
harleyjohn45
i buy all starters and altenators at auto zone. they are cheaper and guarranteed as long as you own the vehicle. they have stores all over the country. i keep the reciepts in with my insurance papers. they can pull it up on any computer in any of their stores.
