For tire rotation for one, is it ok to use a floor jack under the front and rear axles, if placed close to the wheels, so I can put a jack stand under the axle ? Or do I need to jack up the fram instead to get the wheel off the ground ?
I used a floor jack and jackstands to rotate my tires and it worked fine. I even lifted the front end all the way up with the solid front axle (04) and the extra weight of the diesel. Just make sure to use jackstands too
I argree jack stands are a must, that thing is heavy! just want to add-> make sure you never jack it under the differential; Ford says it causes cover leaks.
Thanks for all the help. I learned about the advice of jack stands through a discussion on using Hi Jack. Definitley plan on using jack stands. Question, with the SD, is 3 ton jack and stands sufficient ?
