Predator Programmer for the 05
Old Mar 4, 2005 | 08:28 AM
firegod619's Avatar
firegod619
Can anyone tell me if there are any new down loads for the 05 predator programmer.
Thanks !
Old Mar 4, 2005 | 08:34 AM
FTE Ken's Avatar
FTE Ken
Takes 5 minutes to find out yourself: ww<!-- -->w.diabl<!-- -->osport.c<!-- -->om
Old Mar 4, 2005 | 04:54 PM
ttsupra94's Avatar
ttsupra94
I am about to install mine but i'm curious about the "cold starts". Does that mean just start it up and start driving with no warmup time but still take it easy? They dont go into much detail with that. I just want to double check.
Old Mar 4, 2005 | 06:55 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
If you go here
https://www.ford-trucks.com/forums/s...d.php?t=303583
Then scroll down to
Torqushift Shift Relearning Strategy
It will help you to understand what "TS learning" means.....
Old Mar 4, 2005 | 07:08 PM
ttsupra94's Avatar
ttsupra94
I understand that there is some "learning" involved but they said to do like 5 or 6 cold starts and i dont think that they meant that process from the above article or do they?
Old Mar 4, 2005 | 07:10 PM
IB Tim's Avatar
IB Tim
Yes a cold start is that...IMO, over night "cold"
Meaning like five days.....or four if you line in a real cold place...
Old Mar 4, 2005 | 07:23 PM
ttsupra94's Avatar
ttsupra94
Once a day, that sucks! I'm driving about 100 miles a day to work, so i'm guessing it would not be a good idea to drive it to work while i'm doing the cold starts?
Old Mar 4, 2005 | 07:50 PM
IB Tim's Avatar
IB Tim
There ya go....if you do not drive it at lunch ...it will prolly cool off, so you could get two out of each day....
Old Mar 4, 2005 | 08:00 PM
ttsupra94's Avatar
ttsupra94
And no i do not drive it at lunch, it sits for at least 8 hours. And sorry to jack your thread firegod.
So it would be ok to drive it work while doing the cold starts?
Old Mar 4, 2005 | 08:11 PM
IB Tim's Avatar
IB Tim
Yes do drive it.....
Old Mar 4, 2005 | 11:38 PM
jdadamsjr's Avatar
jdadamsjr
It's not as bad as all that - really....
i've switched tunes and gone right out and drove it...
And I USUALLY don't jump to full WOT starts when cold so it shifts a LITTLE firm until it figures out what my new driving style is (this week )... (the 5,000 foot view explanation)
Some have switched tunes between dragstrip runs... but I've not...
Be sure to update your predator with the correct latest version from here:
www.diablosport.com
and if you'd like, do the tranny relearn thing (although I've never in two years of owning the predator)
maybe I should try it ......
Old Mar 5, 2005 | 12:19 AM
ttsupra94's Avatar
ttsupra94
I looked at updating it but I wasn't sure which version i had. I will have to turn the thing on and see which version it is. Thanks for all the info fellas.
Old Mar 5, 2005 | 09:33 AM
jdadamsjr's Avatar
jdadamsjr
TT -
well, u r right !
u do need to know where you're starting to know how to get where you are going
but if your's is a newer one, would guess it's the r76 version u need from here : http://www.diablosport.com/Downloads.php
I just downloaded the new R35 so I can remove that pesky speed limiter on the 100+ hp tune
Old Mar 5, 2005 | 02:56 PM
ttsupra94's Avatar
ttsupra94
Alright, well i installed it and it seemed to go alright but i have to say, i didn't really notice much of a difference in shifting. I do have a question though, during the install, there are multiple times when you have to "turn the ignition on", "turn the ignition off" or "turn the ignition on but do not start the engine". For the "turn the ignition on" i just turned the key but did not start the engine. Was i supposed to start the engine? At the end it did say the 65hp tune was installed and i didn't get any error messages but i just wanted to check. I was taking it very easy so i couldn't smash the pedal and see the difference
Old Mar 5, 2005 | 03:22 PM
jdadamsjr's Avatar
jdadamsjr
u need to turn it such that it is ON, but not started...
(your door warning dinger should come on)...
and no never start it until after completed...
It has to do a few things each time you load a tune..
the first time it is saving your vin so it marries it to YOUR truck
it also backs up the stock tune to the predator,
then it loads the new tune from the predator to the engine control computer and the a second "tune" to the tranny control tuner...
then it has to reset the PAT (Passive Anti Theft) system with a few of the last on and off cycles....
so yes, there's a bunch of them
you don't have to be TOO gentle with it, let it warm up and then you should notice at about anything more than grandpa level acceleration that it responds a LOT betta !!!
