Short?
Old Mar 4, 2005 | 12:45 AM
samwe's Avatar
samwe
Short?
I found my battery not holding a charge.
I disconnected a cable and used a test light inline and it light up.
What is the next step in identifying the short?
Old Mar 4, 2005 | 04:57 AM
trike1946's Avatar
trike1946
Pull fuses one at a time to see what circuit it might be in. If the fuses don't change anything unplug the alternator and check that.
Old Mar 4, 2005 | 04:18 PM
Franklin2's Avatar
Franklin2
Make sure the doors are shut when doing this testing. The dome light is a load, and will ruin your test.
Old Mar 4, 2005 | 05:42 PM
midlf's Avatar
midlf
Don't forget to disconnect the underhood light if you have one. Same as a dome light, it will give you a false test.
Old Mar 4, 2005 | 06:01 PM
samwe's Avatar
samwe
I have no underhood, and my dome light doesn't come on with the door opening.
This is a '78 F250.
I will work on it tonight. Thanks for the suggestions.
Old Mar 5, 2005 | 01:26 AM
botz244's Avatar
botz244
might be a bad alternator ,not regulartor. might be a bad diode r some thing. disconnect every thing off the alt. see what happens
Old Mar 5, 2005 | 02:15 PM
midlf's Avatar
midlf
Let us know what you found? It will help others to know what your problem turned out to be.
Old Mar 6, 2005 | 04:59 PM
samwe's Avatar
samwe
I did what Botz244 sugessted and I saw no current.
I swapped the alt, and wiring, from my 'parts truck over and no current is flowing...
Thanks for the advice!
