Sponsored by: Auxito
IAC Over Speed Error P1506
Old Mar 3, 2005 | 09:33 PM
RoyalFord's Avatar
RoyalFord
About 3 days ago I noticed my engine RPM was around 250 higher than usual. Usually my truck idles around 550-600 rpm (I know this is low).
Anyway, yesterday it threw the P1506 "IAC over Speed Error" Code. It is idling very rough, shifting weird, but does crank up fine.
My truck is now at 93,000 miles and I just cleaned the IAC at 87,000 miles due to the common no start condition. I guess I am going to get a new IAC now since another code came up.
Well, my question is it came up with two other codes also:
• P0171 - System too Lean, Bank No. 1
• P0174 - System too Lean, Bank No. 2
Do you think the P1506 (IAC Code) made the O2 Sensor codes show up or is it really the O2 Sensors? I just changed my two upstream O2 Sensors around 90,000 miles.
Do you guys think I should get a new IAC or try to clean it again?
Thanks so much.
Old Mar 3, 2005 | 09:53 PM
cantrma's Avatar
cantrma
Neither. A vacuum leak is causing both. Once in closed loop where the O2 sensors adjust the mixture based on the exhaust, a vacuum leak is just like a wider open throttle. It lets in more air, the computer playing off the leaner exhaust adds correspondingly more fuel so it runs smoothly, just faster. Although the computer commanded more fuel, it realized that it had to add much more fuel than the amount based on the amount of air going through the MAF. Since it had to add more fuel, it concludes the engine is lean. Since the IAC closes but the engine RPMs are still up (because of the vacuum leak) it sets to IAC failure to control code.
Use a length of fuel hose to your ear to listen for the leak. Especially check for rotted hoses on the PCV, at an elbow behind the throttle body.
Old Mar 4, 2005 | 09:06 AM
RoyalFord's Avatar
RoyalFord
Thanks for your response cantrma.
I guess I will check for vacuum leaks then. I mean that could be the problem but I am going to go ahead and get a new IAC. Just to get that out of the way.
Old Mar 4, 2005 | 09:25 PM
RoyalFord's Avatar
RoyalFord
ok guys it is a vacuum leak. The back 90 degree hose fitting that comes from the PCV valve and connects to the back of the intake.
I went ahead and bought a new IAC for $78.50. I am going to go ahead and install the IAC and get a new hose fitting in the morning.
IF YOU ARE HAVING PROBLEMS WITH THE TRUCK IDILING, CHECK THAT HOSE!
Old Mar 4, 2005 | 09:45 PM
xallxforxchristx's Avatar
xallxforxchristx
hmmm...I'll look over the hoses to see if this is my problem too. You don't happen to have the 5.4 and could yield any tips on removing the IAC do you? Also, I noticed you said you changed out your O2 sensors. Do you know the recommendations for how often these are to be changed?
Old Mar 4, 2005 | 11:47 PM
RoyalFord's Avatar
RoyalFord
Yes, I have a 5.4L as you can see in my signature.
You can get to the IAC without removing the throttle body or intake manifold spacer. The IAC is mounted on with two 8mm bolts. It is easy to get to with a 1/4 drive and a universal joint. It might not look like you can get to it but you can.
I wouldn't change the O2 sensors until you start having problems. Actually the upstream (closer to the engine) O2 sensors are the ones that only need to be changed most of the time. The downstream (towards the tail pipe or muffler) O2 sensors never give a lot of trouble. We do have four 02 sensors in all.
Old Mar 5, 2005 | 12:01 AM
xallxforxchristx
thanks, that's what I needed to know.
Old Mar 5, 2005 | 10:59 AM
RoyalFord's Avatar
RoyalFord
ok guys everything is fixed now. Truck runs great!
I installed a new IAC and the PCV valve hoses (They all come together).
Old Jan 2, 2012 | 02:15 AM
Runarenis's Avatar
Runarenis
i know this post is very old but i had the same thing happen to me yesterday same 3 codes and its not that elbow. Could it be the intake gaskets?
Old Jan 2, 2012 | 08:16 AM
cantrma's Avatar
cantrma
Yes, any vacuum leak would cause the same results. Brake booster hose, any vacuum hose, the heating and cooling controls, gaskets, any of the common vacuum leaks. Good luck.
Old Jan 15, 2012 | 11:42 AM
RoyalFord's Avatar
RoyalFord
The original leak was hard for me to find. Just search google "how to find vacuum leaks."
Old Apr 18, 2013 | 06:24 PM
mferrell's Avatar
mferrell
I get a P1506 code,and can hear possibly a vacuum sound comeing from behind and to the left of the insturment cluster, that will change if the throttle is opened wide and quick. What is behind there??
Old Sep 18, 2015 | 12:20 AM
Sand Obsessed's Avatar
Sand Obsessed
Today My 460 97 F350 threw out two codes, P 1506 CNF
and
P 0320 PND
Engine coughed and sputtered for a split second, then fine...
Nano second...
So me too...
Searching for vac leaks? anything else?
Old Sep 18, 2015 | 10:43 PM
Bluegrass 7's Avatar
Bluegrass 7
Sand,
while you have a 97, it is an older push rod motor and is not equipped with all the same system.
I would say if you look up the 320 code, it would suggest what your issue is.
There is no 320 code for the rest of the engine families being discussed in this thread.
I don't feel a vacuum leak is your issue either.
The 1506 code is the same because it is the same type part on both engine families so the code description will be the same, in this case but not for code 320.
Good luck.
Old Mar 4, 2018 | 07:26 PM
Davidsherrill's Avatar
Davidsherrill
Idle
I have a 2000 Ford Ranger 2.5 Rough idle Every time I Bring RPMs up high then let off it idles down real low and dies what could be the problem I have already changed just about every sensor on motor And took throttlebody a part and cleaned
