inertia switch
Old Mar 3, 2005 | 10:34 AM
keeper's Avatar
keeper
inertia switch
I have '89 E150 W/5.0. This van was running fine it simply died.There was no indications of anything going bad.It simply quit.B/4 I go into the expense of replacing the hi PSI fuel pump I would like to make sure the inertia switch hasen't been tripped.Its really hard to check if I can't find it. Thanx.dead without a reason
Old Mar 4, 2005 | 09:24 AM
wickymustang's Avatar
wickymustang
On my 95 f150 it is in behind the kick panel under the dash on the passenger side.
Old Mar 4, 2005 | 04:46 PM
LxMan1's Avatar
LxMan1
Look up above the pedal area too, it could be there on the inside of the firewall near the fuse box.
Old Mar 5, 2005 | 02:04 PM
keeper's Avatar
keeper
Thanx,I found the switch.passenger side beside th heat/AC unit.It wasn't tripped I by passed the fuel pump relay.The hi psi pump works.It is on frame rail under drivers throne.By bipassing the fuel relay,pump runs continus.I didn't have a pressureguage,butthere's fuel.When I hit th ignition it fired,but didn't stay running.Gave it a shot of ether and she cranked right up.The motor ran smooth for about 30/40 seconds and died.Hit ign again,no ether,motor hit 2 or3 cyl dies.The van has dual tanks.Both tanks are full of fuel.I just can't picture both of the in tank pumps going out.Could my problem be in fuel tank selector?
Old Mar 7, 2005 | 02:47 PM
yendor's Avatar
yendor
LxMan1 Should the button be up on the switch or stuck down?
Old Mar 7, 2005 | 09:49 PM
LxMan1's Avatar
LxMan1
Stuck down unless it is tripped. It will pop up when jolted hard.
