I was driving my 95' F-150 the other day and happen to look down at my dash and the speedometer was not working at the same time my abs light was on and won't go off and on top of that the the "Off" light for my overdrive(on the gear shift) blinks. Can someone please help me
The ABS and the speedometer share the same sensor in the rear axle. It's right on top of the differential. I would check the connections at the rear end.
Joe
94 Bronco XLT,5.8,E4OD,4" skyjacker lift,K&N FIPK,Custom SS Exhaust
Joe,
That was it. Thanks so much! you know it made since when I read your reply because last month I had my dual exuast redone and they had problems going over the rear end they must have pulled one of the wires. Thanks agian!! This is a great site I'll be back
