A "heads-up"
Old Mar 2, 2005 | 05:32 PM
Missouri Mule's Avatar
Missouri Mule
A "heads-up"
A couple of things I have run across just in the past couple of days. My F-150 STX I took delivery on a month ago did not have a bedliner. I had a drop in bedliner in my old Ranger that I replaced with the spray-in liner. OK, but not perfect. I decided that I would just make do with the rubber mat this time as I am not going to be doing any heavy duty use of the bed. I found a perfect fit mat at Tractor Supply in Athens, Texas yesterday for $53. These stores should be located in several places in Texas and elsewhere. That's a good price as I was quoted about $75 for one at O'Reilly's and that was a "universal" fit that I would have to trim -- no thanks.
Second thing is that I need to get a Class III hitch and I just received word from ETrailer out of St. Charles that they now have them that will fit the trucks with the vibration damper. My order is on the way. $135 plus shipping. Do not get one that is not earmarked for the vibration damper as it will not fit. Even my local Ford dealer didn't have one in stock.
Old Mar 3, 2005 | 12:49 AM
Ruckus's Avatar
Ruckus
What size bed do you have? 5.5 , 6.5 , or 8.0 FT.? If less than 8ft. did you have to trim mat?This sounds like a great price.Good Luck!
Old Mar 3, 2005 | 07:58 AM
Aubrey3's Avatar
Aubrey3
Is the mat thick enough to really take a beating? I went to the local pep boys and thought those mats were weak.
Old Mar 3, 2005 | 12:15 PM
Missouri Mule
It's a 6.5 foot bed.
Old Mar 3, 2005 | 12:20 PM
Missouri Mule
It's a quarter inch thick. I just measured it. Looks plenty beefy to me. However, if one wanted to throw boulders in it then I would probably get something thicker. Tractor Supply also had a bunch of rubber mats out front that were about 1 inch thick. One would need two of them and they would have to cut to size if one needed something that thick. They were $40 if I recall, but the one I got seems suffiecient for my use. I just stumbled onto the mat as I was leaving the store. I took it out there and it fit perfectly.
I've been notified that my hitch is on the UPS truck and I'll post the results after I install it. Supposed to be a bolt on affair taking 30 minutes.
Old Mar 7, 2005 | 11:29 AM
Missouri Mule
The UPS man delivered my hitch this morning. Looks good but I haven't yet put it on as it is raining. That didn't take very long at all as I just ordered the latter part of last week.
Old Mar 8, 2005 | 11:25 AM
Missouri Mule
Installed the hitch yesterday afternoon. That thing is heavy to lift underneath the truck but managed with my floor jack. And that vibration damper is equally heavy. Guess I am getting old. Went on as described except it took me considerably longer than instruction sheet said. Don't even attempt this unless you lower and remove the spare tire. And remove the vibration damper and get it out of your way.
The procedure goes fairly smoothly. It is necessary to fish the bolts and backing plates through the frame using a spring arrangement, otherwise it would be impossible. But it works fine. The vibration damper is moved to the left and out of the way with an extra bracket and one 7/16" hole must be drilled to accomodate the bolt and nut. But it all worked out and I'm back in business.
This would be a good project for any do it yourselfers to tackle.
