Sponsored by: Auxito
speed sensor
Old Mar 2, 2005 | 04:21 PM
richdb's Avatar
richdb
speed sensor
Having shifting problems. rough shifting and then will not shift into second, rpms go up and then the speedometer goes to zero. Will not go unless I shut down and then start and put shift selector in D2 and then it will limp in to the house or shop. But this has never happened when at the shop or dealer. The transmission shop says that the tranny is fine.......took it to an electrical shop and they replaced the speed sensor on the rear axel. Still having intermittent problems. Any ideas or has anyone had this problem. F-150, ext cab, 5.4, 4 x 4.
Old Mar 2, 2005 | 06:57 PM
LxMan1's Avatar
LxMan1
I believe that the sensor on the rear axle is for the ABS. Isn't there one in the transfer case too?
