Help with Gauges
Old Mar 2, 2005 | 01:29 PM
LordBlade's Avatar
LordBlade
Help with Gauges
I just received my two pred. from motor haven and want the gauges necessary to watch exhaust temp and boost. Having a little problem can someone give me the correct gauge part numbers from motor haven.
One truck is a 2003 6L and the other is 7.3L.
The 6L needs the 0- 60psi boost gauge how about the 2002 7.3L does it need 60 also or is 30 enough?
Also do I need pre turbo part#R 3607T or post turbo part# R 3607 VW
These applies to both trucks. I am ready to order and would like to know which ones to get. Is weld on tap easier/better to install?
Soon to be
Old Mar 2, 2005 | 04:15 PM
waynerb's Avatar
waynerb
I went to another site that has them and put it together in an e-mail to motorhaven. We will see what happens. I also have an 03 so I went with, R5659R Trans, R3607TR Pyro/pre, R5623R boost 0-60 the r at the end is the color of the needle red. good luck
Old Mar 2, 2005 | 08:50 PM
LordBlade's Avatar
LordBlade
Pred Installed
Just installed the Pred. Gota take it easy for now till I get these gauges picked out.
