Straight-pipe a 302?
Old Mar 1, 2005 | 07:55 PM
MemOrex's Avatar
MemOrex
I plan on doing some exhaust work on my 302. I want True Duals. At home, I have a lot of pipe that I can use. I want some single-chambered flowmasters as well.
If I run true-dual straight pipes, can it hurt the engine. The piping size is 2¼. I plan on adding the flowmasters later. I know it will be LOUD, but does anyone have experience? Thanks
Old Mar 1, 2005 | 07:58 PM
Mudrover06's Avatar
Mudrover06
My 302 has straight pipe after the cats and it sounds awesome, it sounds like and overly agressive flowmaster sound that is very deep i love it i plan on keeping it just the way it is
Old Mar 1, 2005 | 08:05 PM
MemOrex's Avatar
MemOrex
I had straight pipe after the cats as well. I cut one cat off and it got louder. But, I wonder if cutting the other cat off and running dual straight pipes hurt it.
Old Mar 1, 2005 | 08:16 PM
chrono4's Avatar
chrono4
well if the pip is to short, or has no restriction at all, the exhaust valves could cool to rapidly and cause them to crack, but alot of people have run straight pipes with out damage, its just the posiblity. i have cut everything off but the first cat, and i plan on gutting that this weekend, and runing out the side with a glasspack. i think you should be fine as long as your not just running headers and no pipe.
Old Mar 1, 2005 | 08:22 PM
MemOrex's Avatar
MemOrex
Hmm...I think I'll wait it out till I get some $$.
Right now I have a 12" glasspack with side-exit. I also only have that one small cat. I might gut it and see what that does
Old Mar 1, 2005 | 09:47 PM
kens64's Avatar
kens64
Be sure you fill the inside with a piece of pipe. The large hollow hole left by the gutted cat will slow down exhaust flow.
chrono4- I have heard that story too. I have yet to see it actually happen, but I guess it could, in an extreme case.
Old Mar 1, 2005 | 09:56 PM
MemOrex's Avatar
MemOrex
I can't put a pipe inside the cat since it has both pipes from the manifolds going into it.
Old Mar 1, 2005 | 10:09 PM
kens64's Avatar
kens64
Then, IMO, dont gut it. You will get more sound, sure, but exhaust flow will never be as good as it can be.
Old Mar 1, 2005 | 10:37 PM
chrono4's Avatar
chrono4
well i know that cats reduce flow alot, and they absorb lots sound, and they make lotsa heat. when i gut mine im just gonna leave it hollow, kinda like a resonator
Old Mar 1, 2005 | 10:52 PM
MemOrex's Avatar
MemOrex
chrono4, let me know how it works out. both you and kens64 make some good points.
Old Mar 2, 2005 | 07:27 AM
chrono4's Avatar
chrono4
well i should be gutting it this thursday so ill let you know
Old Mar 4, 2005 | 03:35 PM
Marc150's Avatar
Marc150
93GreenF150, I just wanted to ask you how big was the pipe the now departed-cat connected to? Was it the same as the tailpipe (mines 2 1/4) or was it 3in? It looks perty big to me but I figured you'd know!!
Old Mar 4, 2005 | 08:49 PM
MemOrex's Avatar
MemOrex
Im pretty positive it's 3in.
Well, right now the glasspack just isn't cutting (soundwise) it. lol. I'm torching it off. Besides, I'm not really fond of that 'backrap' it does.
Hmmm...I'm still kinda thinking of true-dual straight pipe. Only thing getting in my way is that darn air injection tube down there. We'll see what happens
Old Mar 5, 2005 | 04:19 PM
MemOrex's Avatar
MemOrex
Ahhhh...glasspack is OFF! Back to that Sweet, SWEET sound!
Im gonna cut open that glasspack and take all the packing out, and re-install it. Later though, I just LOVE this sound right now!
Old Mar 13, 2005 | 07:37 PM
MemOrex's Avatar
MemOrex
Well, spring break is here, but I have to work . BUT, that also means i'm home which I can get started on my straight pipe project . What I'm gonna do is, cut that first cat off. It's a Dual In so, that makes the job easier. I'm gonna run the pipes from there.
What's gonna get me is how to run the pipes over the frame rail. I need to get me some pre-bent pipe. After that, it's easy. I'm only gonna run the pipes to about where the middle U-joint is. After that, I'm gonna put some flowmasters. Then exit both pipes before the passenger rear tire. Alright.
