Power loss after work done
i was in the middle of fixing the air conditioning unit and listening to the radio in my 77 ford truck and when i was just finishing putting the air conditioner back in its harness the truck just shut down now it wont start play music or show any sign of power what could of caused it to do that? anybody plz tell me thx
Zach
Zach
Last edited by Mil1ion; Mar 2, 2005 at 07:31 PM. Reason: Bogus Title edited to be describe the TOPIC
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE
Enjoy FTE
So there is no power inside the cab? Sounds like the fusable link. They are integrated into the wiring near the starter solinoid. On the bettery side of the solinoid there should be a couple smaller wires - go about 3-4" down the wire and test them for power by stabbing with a test light, if no power then the link has melted and needs replaced. They can be bought at any parts store, be sure to solder them in and cover with heat shrink tubing.
Let us know what you find.
Marty
Marty
Check your fuse panel for main power to make sure you are getting power into the cab. I had the same problem when I went over a set of rail road tracks my truck died, Im talking no lights, hazards, or anything. Checked all the fuse links and I didnt have power but it was not the fuse links it turned to be my main power the feeds the fuse panel was spliced and came loose from its connection. So my conclusion is that those fuse links are fed from the cab so if now power to cab no power to fuse links. My truck is also a 1977 the main wire to my fuse panel is a large black wire with a yellow stripe on it. Hope this helps I know mine drove me nuts until I found it.
