1978 - 1996 Big Bronco
Steering Gear Box
Old Mar 1, 2005 | 03:53 PM
SproutW's Avatar
SproutW
Steering Gear Box
Ok, it's been several years since I've replaced a steering gear box in one of my Broncos. This Bronco (1994) is my daily driver and I want to finish the project and not be stranded. For those of you that recently replaced you steering box, I'm looking for the time involved. I can't remember if this was a couple hour process or a whole day circus. For those of you that witnessed my earlier post my rag joint was fine. I attempted to adjust the box again with no luck. Only thing left to replace now. Thanks.
Old Mar 1, 2005 | 04:34 PM
SRD4X4's Avatar
SRD4X4
An hour or 2,unless you have friends like mine that show up with 30 packs and all the knowledge known to mankind.Then it is an all day job.2 p/s lines,4 bolts,1 nut on pitman arm.
Old Mar 1, 2005 | 05:37 PM
aurgathor's Avatar
aurgathor
If you can't remember, it can't be *that* bad. I'll never forget my rear main oil seal, for once.
Old Mar 1, 2005 | 06:35 PM
94 XLT White/ Silver 302's Avatar
It shouldn't take any longer than a couple hours if you have all the tools. pitman arm puller, torque wrench, 1-5/16" socket to remove pitman arm nut, soak down the p/s fittings and the pitman nut with penitraiting oil the day before.
Old Mar 14, 2005 | 09:36 AM
SproutW's Avatar
SproutW
Just wanted to give everyone an update. I replaced by Steering Box in under two hours. Everything (remarkably) went smooth. Thanks again everyone!!!
