Which 460 mount kit is better?
Of the two mount kits offered to install a 460 in a 53 f100 which would you recommend? The crossmember style or the side mount style? The engine I am using is out of a 78 Lincoln and I've seen where both styles say to not use with Lincoln or Mercury motors. I am assuming this is an oil pan issue which is no big deal to overcome.
I did a search on this first but I really didn't find the answer. Thanks in advance.
on
it kinda of depends on what else you are doing to truck.
If you are sticking with the stock I beam front end, the crossmember style would probably be the easiest to install (it basically bolts to the frame) and also an added benefit is that it will stiifen the front end. Drawback being that if you ever want to put in a larger capacity pan, the pan probably won't fit.
if you are going with an independent front end (MII or equal) I would use the side mount. (wish i had with my truck, 60 ford with MII crossmember kit). it will give you the most clearance and flexibility as to placement. I takes a little more patience to install properly and you would probably have to box the frame.
the main reason they say not to use Lincoln or Mercury is that they use different motor mounts than Ford. the pans are the same. You can use a Lincoln or Mercury engine as long as you use the correct Ford motor mounts ( which I think are from a mid 70's Torino or LTD, can't remember exactly)
rgds
Mike
rgds
Mike
61UniB100
01-30-2007 10:34 AM
olfordsnstone
09-05-2004 03:00 PM
