460 accessory help needed
Old Mar 1, 2005 | 01:25 PM
79BigBlock4x4's Avatar
79BigBlock4x4
Ive decided to put power steering on my truck, along with the original alternator bracket, but i cant find a diagram on how everything should look once on the motor. I have all the parts, they were in the bed when i bought the truck but i wanna see a drawing or something on how this should all mount so nothing will get messed up. Thanks.
Old Mar 2, 2005 | 10:50 PM
masterbeavis's Avatar
masterbeavis
year and application would help. I would assume you are talking about a '79 4x4? if the motor came from a 2wd truck, your power steering pump might hit your steering gear. If it came from a passenger car (it will be a saginaw pump, looks just like GM) then it wont hit. best place for ideas is to look at motors in the wrecking yard, or do the 'ol try by trial and error.
Old Mar 3, 2005 | 02:39 PM
Mil1ion's Avatar
Mil1ion
Does it have AC ?
Does it have upper bracketry or lower bracketry ?
Ford Plastic pump or Saginaw (looks like Ham can) Pump ?
Old Mar 3, 2005 | 03:35 PM
79BigBlock4x4
Originally Posted by Mil1ion
Does it have AC ?
I found the pics finally after digging threw this site for about 2 hours. Thanks for help guys.
Old Mar 3, 2005 | 04:05 PM
hawkrod's Avatar
hawkrod
Dang your going to be in for a big surprise! I am assuming by your screen name that you have a 4X4 with a 460 swapped into it right? If thats the case then stock 70's brackets will not physically fit your truck anyway. Going to be fun to say the least. Hawkrod
Old Mar 3, 2005 | 08:24 PM
79BigBlock4x4
Actually, i dont know what year these brackets came off of, or what for that matter, but they bolted right up. Everything is aligned just right. Its a low mount and clears the framerail by about 2 inches so. No worries here.
Old Mar 5, 2005 | 11:01 AM
masterbeavis
Yeah, you did get lucky!! You must have bought a passenger car motor....
Old Mar 5, 2005 | 11:52 AM
hawkrod's Avatar
hawkrod
Nope, can't be a passenger car motor. The brackets for a passenger car conflict with everything in a 4X4. I think it is likely a later Van or Truck engine as those will fit in the right combination. Car brackets cause the alternator to hit the frame and the power steering pulley to hit the steering box (except the cars with GM steering pumps). Been there tried all of that! LOL Hawkrod
Old Mar 5, 2005 | 12:11 PM
460f250's Avatar
460f250
That must've been what one of the previous owners did on mine. The front crossmember has been notched in the right corner where the alternator sits. I don't prefer the look but haven't looked for other brackets to move it.
Old Mar 5, 2005 | 11:11 PM
Mil1ion's Avatar
Mil1ion
E-350 vans with 460's have them
Old Mar 6, 2005 | 12:35 AM
460f250's Avatar
460f250
Thanks.
How do you possibly remember everything you come across in these forums? I have trouble remembering what I had for breakfast.
Old Mar 6, 2005 | 04:41 PM
Mil1ion's Avatar
Mil1ion
Some people are blessed with the ability to remember certain things.
Others are blessed with being able to do certain things.
The biggest challenge is for a person to be able to do both
Old Mar 6, 2005 | 08:52 PM
Bubba Blue's Avatar
Bubba Blue
Red face
Originally Posted by 460f250
Thanks.
Dwayne, you made me laugh. I totally feel your pain, hell, I'm living it...
Regarding the 460 swap, it's got to be the most discussed issue with our old Ford 4x's, getting that big block in where Ford never put one. Lets face it, if there were magic bullet part #'s, Car, van or truck big block brackets, for the A/C, Alt, and PS, those part #'s would be all over this sight, and L & L would not have gone into business. But they did and for good reason, it is a challenge to get the alternator off the right frame rail and the power steering pump off of the steering gear, and the AC mounted with belts lined up with the crank pulleys and still be able to run the other stuff, with properly lined up and tensioned belts..., well you all know this. So we modify, and search the wrecking yards, and are always looking under everyones hoods to see how they did it. Call L & L, it's not quite as fun as fabricating perhaps, but that stuff fits, first time. I found that out on my third 460 transplant. (besides no memory, I am a slow learner) Good luck with it all, -Dale
Old Mar 8, 2005 | 08:31 AM
460f250's Avatar
460f250
And he's a wise man to boot.
