swapping out 360
Old Mar 1, 2005 | 07:36 AM
bigrackhunter's Avatar
bigrackhunter
swapping out 360
I have a 75 F150 with a 360 4spd 4x4, i'm wanting to replace the 360 with a 460 trying to find out what problems i might run into before i start the project.
thanks.
T
Old Mar 1, 2005 | 10:03 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader
i did that swap in my 76 F-150 2wd auto, i bought an engine and tranny together so i didnt have to worry about bellhousing issues, you will need to get all the accessory brackets that goes on the 460, none on the 360 will interchange, well i used the PS bracket from the 360 but i had to heat it with a torch and bend it to make it line up right.......you will need the engine mount towers off the frame, they are totally different between those 2 motors.......just make sure when you get the 460 to get EVERYTHING that attaches to it, just so you know your at least close to having all that you need...
Old Mar 4, 2005 | 08:55 AM
bigrackhunter
thanks, maybe i'll just install a 390 instead.
Old Mar 4, 2005 | 03:32 PM
ford390gashog's Avatar
ford390gashog
this topic has been talked about over and over there are few hundred of the same 360 to 460 topics check out the other ones with the search button.
