Accelerator Pedal Sensor
Old Feb 28, 2005 | 08:12 PM
AutoDoc's Avatar
AutoDoc
Hello i was woundering if any one has come accross this problem?
2002 F350 Super Duty 7.3
Fuse #45 in the Central box blows every so often when fuse goes the truck will only idel accelerator will do nothing this is not an adjustable Accelerator Pedal
also some gauges do not work replace the fuse and its good to gofor a couple of days looks like the dash overdrive cansel switch and Accelerator Pedal are on this circut i have done every thing to try and reproduce the occurance with no avail i give the truck back and sure enouge a couple days latter back again
so my question is has any one run accross somthing like this or are there any bulitins on this subject not the adjustable one ??
Old Mar 22, 2005 | 10:37 PM
mboegler's Avatar
mboegler
Thumbs down
I have the same problem with my 2002 F250 7.3 But I do have adjustable pedals could this Be causing the problem?
Old Mar 23, 2005 | 03:27 PM
AutoDoc's Avatar
AutoDoc
I had found the problem it is in the Over Drive switch wire in the colmn just take
the cover off and look at the wire you may find it cut from wrong routing in the factory
