New Gauge Mounting
Old Feb 28, 2005 | 07:13 PM
garypettengill's Avatar
garypettengill
New Gauge Mounting
I know this has been beat around lots but here's another option. Check out my gallery and you will see. I found this gauge pod at a local "tuner" aftermarket parts store. It is actually mounted using 2 sided foam mounting tape and all the wiring/tubing runs down the corner of the defroster duct opening. I have a real fobia about making new holes in old sheet metal to mount aftermarket stuff. If you get tired of the aftermarket stuff and it goes away you are still left with the hole. I mounted a mechanical oil pressure gauge, an electrical water temp. gauge and a tach. Took a little searching to find a 2 1/16" tachometer. I tee'd my oil pressure sending unit and found another spot for the water temp. so my factory gauges still function.
