b2200 smokes till warm
Old 03-04-2005, 11:33 AM
88blkranger's Avatar
88blkranger
88blkranger is offline
the truck is a 91 b2200 ex-cab. when you first start it up it pours out a thick cloud of smoke. I smelled the cloud and it's oil. it stops smoking when it gets warmed up. is this the valve guides and seals leaking oil after shut down?? this is the carbed 2.2L engine. I need to know if the repairs can be done at home or is there an additive to stop/slow the leak until i get the funds to have a shop redo a head for me.
Old 03-04-2005, 03:42 PM
Steina's Avatar
Steina
Steina is offline
CO River Rat
I assume it's blue smoke? The best way to tell if it's valve guides or rings is to do a compression check, then squirt some oil in the plug holes and do another check. If the readings come up, the rings are worn; if not, it's the guides.
Steve
Old 03-04-2005, 04:41 PM
88blkranger
thanks
alot I was going to do that testing
Old 03-04-2005, 04:45 PM
Steina's Avatar
Steina
Steina is offline
CO River Rat
Good luck - hope it's the guides!
Steve
Meydawg51
07-31-2015 09:57 AM
osu711
01-12-2015 05:44 PM
antman8759
1997 - 2003 F150
02-28-2011 06:39 PM
tim5whs
1997 - 2003 F150
02-17-2008 07:40 PM
cleebmx
08-15-2007 03:10 PM
Quick Reply: b2200 smokes till warm
