Right Valve Cover
Old Sep 6, 2001 | 09:23 PM
bsprowl's Avatar
bsprowl
Right Valve Cover
I have an '88 F150, 302 (5.0) with EFI. Can the right valve cover be removed without taking the upper intake manifold off? I've got an oil leak and need to know what gaskets to get.
Bob
'66 7 Litre, top loader, 3.25 Traction-lock, Sidewinder Intake, SCJ Exhaust
'88 F150 LWB 4x2, XLT Lariat, 302, 5 speed, 3.08
'99 Ranger, 4x2, 3.0, 5 speed, 3.73 posi
Old Sep 7, 2001 | 08:25 AM
lanero's Avatar
lanero
Right Valve Cover
Might as well just pull the upper intake anyway. For one, I don't think the valve cover will come off with it on, and 2, when I removed my upper intake ('89 5L), the gasket was toast. Just pick up the upper intake gasket kit. It comes with the upper intake gasket, and all the gaskets for the TB. I think the kit I got was from Mr. Gasket and cost abot $12.
Roger Lane
Test Analyst
Sr. Automated Test Engineer
IBP, Inc.
Old Sep 10, 2001 | 09:33 AM
RGAZ's Avatar
RGAZ
Right Valve Cover
[font size="1" color="#FF0000"]LAST EDITED ON 10-Sep-01 AT 10:34 AM (EST)[/font][p]I agree with lanero. The intake plenum is actually quite easy to get off, you just need a torx head for the middle inside bolt. Disconnect all the vacuum lines from the plenum and the EGR from the plenum and the TB from the plenum and it comes off easy.
I just did this so its fresh in my mind.
Gaskets are cheap and easy to get.
Randy
BTW-Replace the PCV valve while you are there. Its in the back.
Old Sep 10, 2001 | 06:31 PM
CantDrive55's Avatar
CantDrive55
Right Valve Cover
It can be done without removing the plenum, without too much trouble as long as you have a good set of extensions and a u-joint for your socket. Its a little hard to get out from under there, but it will come out. Pay attention to how you pull it out so you can get it back in easy.
But as the other guys say, it's not that hard to just pull the plenum off. Probably will go easier and faster that way.
Just saying it can be done..
Old Sep 14, 2001 | 09:47 AM
bjoern's Avatar
bjoern
Right Valve Cover
It'd be a sport to take it out without removing the intake. But try to just re-torque the bolts on the valve cover. Sometimes they're just loose!
1988 F-150, V8, 5.0L (302ci), 5spd, SuperCab. Shorty headers, K&N filter, MSD 6a ignition, Accel 300 8.8mm race wires, Accel supercoil, Accel rotor+cap, Bosch +4 Platinum plugs, RanchHand bumper. Soon: Dual exhaust.
http://brembs.net/cars/FordPU.html
Old Sep 14, 2001 | 06:42 PM
lt's Avatar
lt
Right Valve Cover
I did mine also. The "Felpro" gasket was only $4.50 at "Parts Plus". I also changed both valve cover gaskets at the same time. Just do it and get it done - its not hard. You can also drain the oil from the valve cover in the upper intake at the same time.
Have Fun.... Larry
1990 4x4 351 E4OD, Headers, 3" exhaust, etc.
Old Sep 14, 2001 | 09:43 PM
Greywolf's Avatar
Greywolf
Right Valve Cover
