I just bought a 48 f-3 and my battery guy told me the old trucks weren't designed for a whole lot of cca's, and that most people put in heavy duty 6v tractor batteries which are too much. my battery cost 32 bucks and starts my ford great
Don't use a 8 volt battery. You have to re-adjust the regulator to charge it , but the light bulbs may not like the extra voltage. If your engine is timed right, good grounds( most important ) and proper size battery cables, you should be fine. Make sure the area where the starter mounts, the end plates on the starter are clean. It wouldn't hurt to put a ground strap from a starter bolt to the frame.
I've had Optima 6v recommended but haven't tried that. The battery I am using right now is from Carquest and it works good, well, except for other electrical problems... :P
An 8 volt battery wont hurt any bulbs or other stuff, but, you must set the regulator to charge 8V. I had this set up for several years as did a friend of mine with no problems. I recently bought the strongest 6V Interstate Battery has and it works fine in my 55 6V system.
["n 8 volt battery wont hurt any bulbs or other stuff, but, you must set the regulator to charge 8V. "
Agreed. My dad (90 now) always ran 8 volt batteries in his big 6 International trucks, never had a problem with bulbs. He always took the voltage regulator to the electric shop, for some kind of adjustment first. Generator didn't need any tuning.
The original 6V batteries in the 48's had 80 or 90 Amp-Hour ratings. They didn't rate batteries by Cold Cranking Amps (CCA) back then. Most modern automotive 6V batteries of the same physical size (about 10" x 7" x 7.5") have an equivalent of at least 100 Amp-Hour ratings, and would provide good performance.
