Edelbrock heads
Old Mar 16, 2005 | 07:08 PM
deced's Avatar
deced
what wold be the rpm power range on these heads. my 78 bronco is driven every day and some dirt window time would i need ahigh stall tq converter for these heads?
Old Mar 16, 2005 | 08:04 PM
danlee's Avatar
danlee
With a decent cam (Comp Cams 265DEH), the Edelbrock heads should produce over 400 ft-lbs torque from off-idle to past 4000 RPM in a 400 motor with 9.0:1 CR. The horsepower will peak above 330 at 4500 RPM. You would certainly not need a high stall converter with this combination. This is not much better than can be obtained with a good set of iron heads. The combustion chamber design of the Edelbrock heads will have some advantages over the iron heads.
Old Mar 16, 2005 | 08:19 PM
deced's Avatar
deced
thanks for clearing this up to me.
George Fletcher
29
Nov 29, 2025 01:11 AM
mustange70
Oct 13, 2011 01:31 PM
george_c
1978 - 1996 Big Bronco
Feb 9, 2011 05:42 PM
heybrent
Feb 7, 2002 09:41 PM
78bigblock
Sep 27, 2001 07:12 AM
