1978 - 1996 Big Bronco
Transmission
Old Feb 27, 2005 | 11:07 PM
Chef64's Avatar
Chef64
Transmission
I have an 86 Bronco 302 automatic and was wondering if my manual transmission out of my 88 F-150 2wd will work?
Old Feb 28, 2005 | 02:45 AM
justshootme84's Avatar
justshootme84
It would be possible, but you would need the tranny-to-transfer case adapter from the same type of manual tranny your truck has. Putting aside all of the work it would take to add a clutch, some models are nearly bolt-on swaps and other need a different tailshaft, and some need special machining/fabrication to make'em work. If you want more info, post up what types of transmissions you have to make the swap. You can also search the transmissions forum for details. If your 88 F150 has the Mazda 5-speed, it may not be worth the trouble swapping it into the Bronco.
