Sponsored by: Real Truck
02 E450 v-10 fuel pump testing
Old Feb 26, 2005 | 09:56 PM
F2504x4's Avatar
F2504x4
its an Rv sitting on the above chassis,Been sitting a few months,strong battery, No start condition, I've checked all the fuse's under the hood ,all good, and the relay's there are four of them , not sure which one is for the fuel pump, but they are all the same model # so I switched them around ,can feel clicking,but no change in condition. i checked the valve on the fuel rail, no pressure, ( used a nail to check) I can't hear the pump kick in when i turn the ignition on.
What in the color of the wire that supplies voltage to fuel pump ?
I found the quick connect plug at the fuel tank, I want to see if i'm getting voltage to the pump. and anything else i should be checking for?
Not looking forward to dropping a fuel tank with 50 gal. of fuel in it .
Thanks for any info on this guy's
Old Feb 26, 2005 | 10:42 PM
99f350sd's Avatar
99f350sd
Was it driven to where it is now. Isn't there a fuel emer switch in the right kick panel.
Just thinking out loud...I'll check my wiring info
Old Feb 26, 2005 | 10:55 PM
99f350sd's Avatar
99f350sd
Look for pink w blk and brown w white I may be wrong thats for a 99-01.
Old Feb 27, 2005 | 10:44 AM
F2504x4's Avatar
F2504x4
Thanks for the reply, It seems that kent gave it a shot of starting fluid and it started, strange but I will keep the color code written down for future use,.
Once again thank you
biztyke
Jun 12, 2013 01:27 AM
Jymmm
Feb 1, 2013 04:53 PM
1978Crew
Oct 6, 2011 11:01 PM
kzack
Nov 4, 2009 06:40 AM
79malibuonblocks
Jun 25, 2009 06:53 PM
