why is this so quiet???
Old Feb 26, 2005 | 01:08 PM
mattd17's Avatar
mattd17
ok everyone, i have a 99 f250 super duty 5.4L, and i just put on a flowmaster single in dual out 40 series. i put it right after the cat, and had each outlet go straight back, and dump down just in front of the axle. but, it is not much different than stock. do i need to remove the cat? im really not impressed at all with this quiet sound. thanks for your advice in advance.
Old Feb 26, 2005 | 03:15 PM
MemOrex's Avatar
MemOrex
Ford's cats muffle a lot of sound. You can remove the cat, or put a hi-flow cat, for a louder tone.
Old Feb 26, 2005 | 06:03 PM
boxcar1974's Avatar
boxcar1974
Yes cats do cut down the sound alot. On your 99' sd, do you have a 02 sensor after the cat (my 03' sd V10 does)? If you remove the cat will you have to run MIL eliminators to keep from getting check engone lights? Also, I wonder if the computer can compensate for lack of a cat. I put the banks powerpack on my V10, which changed the exhaust system completely except for the cat. Everything else is changed. I changed the banks muffler and put on a flowmaster 70 series instead. I did that because V10's are not V8's so yuck. But anyways it is way louder than stock. It has a costant sound to it. It never goes silent, even at highway cruising speeds. I always can hear it.
Old Feb 26, 2005 | 06:22 PM
mattd17's Avatar
mattd17
i dont have a o2 sensor after the cat, so i wonder if it will damage the engine at all?
Old Feb 26, 2005 | 07:02 PM
MemOrex's Avatar
MemOrex
If there's no O2 sensor after the Cat, the computer won't tell the difference with cat or no cat.
Old Feb 26, 2005 | 07:21 PM
mattd17's Avatar
mattd17
ok, thanks.... i think i will just by-pass it for now and see what happens... i could always put it back i guess if it acts up.
Old Feb 26, 2005 | 08:57 PM
90F1505.0L's Avatar
90F1505.0L
I don't know if you have turn down's but if you do take them off and it will be twice as loud....trust me....
Old Feb 26, 2005 | 09:04 PM
mattd17's Avatar
mattd17
yes, i do have turn downs....... i have dual outs running about 18" then dumping to the road, just in front of the axle...... so should i cut them off at the muffler, or just before it bends down? and if i do cut them off, then should i still leave the cat in, or take it out as well and just run the flowie? thanks again !!!
Old Feb 28, 2005 | 06:35 PM
92f150I6's Avatar
92f150I6
as of now, superduties don't require an 02 sensor after the cat. They are not OBD2 certified because they are too heavy. My 03 doesn't have an oxygen sensor after the cat. I really can't find the exhaust I really want, so I thing I may just replace my muddler with apiece of pipe, and use the stock tubing.
Old Feb 28, 2005 | 07:12 PM
mattd17's Avatar
mattd17
92f150...... that is eaxctly what i tried at first..... it didnt sound too bad, but if i was climbing a hill and hit around 3000 rpm's, then it sounded really high pitched and annoying. what i did now was just remove the cat entirely and have a pipe in its place, then the flowie 40, and have both outlets dumped..... it sounds pretty good. i may have pipes bent to run out the rear and then have nice tips installed.... but i like it for now.
Old Mar 1, 2005 | 07:30 PM
90F1505.0L's Avatar
90F1505.0L
If you cut them off right after the muffler and than remove your cat than you are asking for annoying loud. So if you just remove your cat and leave the turn downs alone and it will be louder than what you have now. Sorry the response is so late. Good Luck...
Old Mar 2, 2005 | 12:45 AM
mattd17's Avatar
mattd17
well 90f150, i did remove the cat and left the turndowns on it the way it was.... i am pretty happy with it. i may eventually put some pipes out to the rear with tips.....
Old Mar 2, 2005 | 07:15 PM
90F1505.0L's Avatar
90F1505.0L
is it pretty loud?
Old Mar 2, 2005 | 08:23 PM
mattd17's Avatar
mattd17
well, i wouldnt say it is too loud...... but it does have a nice deep, mellow rumble. i think it sounds good..... i personally dont want it any louder. it was obnoxious when i pirst just removed the stock muffler and ran a pipe in its place. after 3000 rpm's it was annoying. im pretty happy now.
Old Mar 2, 2005 | 08:40 PM
90F1505.0L's Avatar
90F1505.0L
cool beans dude.....
