U-JOINT REMOVAL
Old Oct 2, 2001 | 06:27 PM
LikeARock's Avatar
LikeARock
U-JOINT REMOVAL
I own a 1981 F250 2wd Camper Special.
I'm replacing the rear and centre u-joints but I'm baffled as to how they come off.There are no snap rings or anything else showing.
There are little holes with I'm assuming plastic fill??At each bearing cap on the cast of the shaft.
Is there a proper way of removinf these.
I have the shaft off and in the vise in the shop,both u-joints being on that shaft.
Any ideas would be appreciated.
Old Oct 2, 2001 | 07:14 PM
lastchance's Avatar
lastchance
U-JOINT REMOVAL
Just did one of these today. Heat it up and that plastic stuff will come oozing right out of the holes, and the ujoint will come right out. The new joint will come with internal snap rings. Just clean all the plastic stuff out so the new one slides in easily.
Old Oct 2, 2001 | 07:23 PM
LikeARock's Avatar
LikeARock
U-JOINT REMOVAL
Thanks lastchance...
I'm on my way out now to try it.
I guess alittle pounding to get it out as well.....
Old Oct 3, 2001 | 07:20 PM
jakegypsum's Avatar
jakegypsum
U-JOINT REMOVAL
Wow! I must say that in all of the different vehicles that I have come across, I have never seen those type of u-joints. Thanks for the info Lastchance. You always learn something new on the FTE site. Jake.
Jakegypsum // Ford fleet, soup to nuts.
Old Oct 3, 2001 | 07:49 PM
LikeARock's Avatar
LikeARock
U-JOINT REMOVAL
Let me tell you that this has to have been one of the weirdest job I've done.
That wax fills the whole groove inside the casting where the where the u-joint cap is.
It needs heating up to melt it out...then they still wouldn't come out.
So out came the torches and I cut them out.
Then trying to find the right u-joints was a chore.
I ended up buying u-joints with internal snap rings....
Just finnished putting them in.
I'll put the shaft back on in a bit.
On my F250 there is 3 u-joints..1 in the front,1 in the centre and 1 at the rear.
The centre and rear ones require the WAX or internal rings as the front one uses EXTERNAL snap rings making its removal much easier.
Again thanks for your help.
I know I'll be back...this site ROCKS!!!
Old Oct 5, 2001 | 01:56 AM
Superdave's Avatar
Superdave
U-JOINT REMOVAL
I have seen joints like this in older (70's) full size GM cars. Usually a good smack or so with a hammer on a piece of cold roll and a reciever socket on the bottom would break the plastic bond at the snap ring groove and the bearing cap.
Superdave
94 Ford Aerostar XL 3.0L
82 Ford F250 4x4 XLT,400 CID,C-6 A/T,8700lb GVWR. Black & Silver
Old Oct 7, 2001 | 08:31 PM
rocky's Avatar
rocky
U-JOINT REMOVAL
Never saw any "plastic" U-joint retainers. Learn something new every time I visit here.
Old Oct 8, 2001 | 03:54 PM
badraven's Avatar
badraven
U-JOINT REMOVAL
Daddyo's garage
WTB - Parts & other
Nov 2, 2013 11:08 AM
TMattson
1978 - 1996 Big Bronco
May 18, 2008 04:12 PM
BroncRyder90
May 7, 2004 08:36 PM
Kenny
Dec 15, 2003 06:43 PM
