Transmission Woes
Old May 17, 2001 | 08:09 PM
Johns331's Avatar
Johns331
Transmission Woes
I have a 95 F-150 5.0 with the AODE trans. a couple of weeks ago, it started to "shudder" when it shifted into OD when under a load. I've been told by two different transmission shops that it is the torque converter, and another shop that it is the OD clutch band slipping. Has anyone had any experience with this problem, and how expensive the fix is? I'm afraid to drive the truck for fear of causing more damage. Also, any suggestions for performance improvements while they have the trans apart? Thanks!
Old Sep 2, 2001 | 05:11 AM
TexasGuy001's Avatar
TexasGuy001
Transmission Woes
I had the same problem with my 95 F150 5.0 with an AODE trans. Autotrans makes a shudder fix circuit board that you put in the transmission and splice into the wires on a solonoid (if thats how its spelled) My truck started doing the shuddering at about 90K miles. Now it has almost 140K with no tranny problems. I've serviced it plenty of times though. Gotta take care of those automatics
Old Oct 8, 2001 | 03:54 PM
badraven's Avatar
badraven
Transmission Woes
Lubeguard is the wonder drug for automatic transmissions. I've been in the transmission industry for years and Lubeguard is awesome stuff. Try it out. About 10 bucks at your local
No Auto Parts Available store. (NAPA)
Jeff
Old Oct 8, 2001 | 04:14 PM
badraven's Avatar
badraven
Transmission Woes
sd75mac
Dec 9, 2012 08:35 PM
canomjm1a1
20
Jun 6, 2005 09:32 PM
Swit
1978 - 1996 Big Bronco
Mar 31, 2004 04:48 PM
Metro-Nut
13
Nov 30, 2003 01:07 PM
