1978 - 1996 Big Bronco
1995 Third Brake Light
Old Feb 25, 2005 | 10:08 PM
irwin51's Avatar
irwin51
I need to replace one of the back-up light bulbs in the 3rd brake light housing on the back of my 1995. But with the 2 screws removed, it doesn't budge. When applying force, I'm afraid of cracking the plastic. Is there a trick, or is it just stuck?
thanks,
Tyler
Old Feb 25, 2005 | 10:19 PM
greystreak92's Avatar
greystreak92
Try wedging a small flat screwdriver under the edge of the housing. There is a foam rubber seal between the housing and the top that is probably holding onto the housing.
Old Mar 1, 2005 | 09:08 AM
jlb911c's Avatar
jlb911c
I had the same problem. The heat from the stoplight bulb melts the frame of the unit and it forms a plastic drip that prevents the unit from being removed. I removed the rear window top rubber from the fiber glass top and found a hole in the center. I then drilled the hole thru and was able to look into the crevasse and with a screw driver remove the plastic that melted. After that the removal was easy.
Do not try to force the thing out, you will break it and it costs $125 to replace.
JB
Old Mar 1, 2005 | 03:31 PM
greystreak92
Its the same stoplight/cargo light unit thats in every F-series. If it does break, boneyard units should be easy to acquire.
Old Mar 1, 2005 | 05:36 PM
tex94F250's Avatar
tex94F250
Roger, streak. If you have a flat butter knife and take a sanding belt and dress each side (talking about one of those wide ones that are fairly thin and pliable) you can carefully work it in and pop it off. If it cracks, like streak says, tons out there on wrecks.
Tyler S
May 21, 2014 11:39 AM
Tyler S
May 19, 2014 08:26 PM
TheBigDirty1
Kentucky Chapter
Mar 7, 2013 09:01 AM
TyCrawf
Feb 14, 2012 08:09 PM
66dieselman
Oct 2, 2011 09:51 PM
