'52 F2 Flatbed
Old Feb 25, 2005 | 02:11 PM
Mark N
Guest
Posts: n/a
'52 F2 Flatbed
Hi Forum, I'm new here so I hope I'm not doing this in the wrong place. I've just put together a '52 F2 and have ended up with a second '52 F2 I'd like to sell, either whole or in parts. In addition, I have at least two relatively complete V8 flathead engines and a couple trannys. I have pictures of the truck but I'm not sure if I can post them here. I can send them to you if not. If this is the wrong place, let me know.
1952 F2 (3/4 ton) Ford pick up with flat bed.
All glass present but every single pane has cracks.
"Ford" flat bed, shown in picture upside down, and backwards, just
resting on frame.
Original brakes, wheels, rear end, suspension. All tires hold air.
Only two small rust holes, one in each front fender. All sheet metal has
been epoxy primered for protection from the weather , hence, light green color. No known bondo, body
filler, or body repair. Good Frame, floor board solid, running boards
present but in poor condition.
No engine.
Old Feb 25, 2005 | 02:25 PM
Randy Jack's Avatar
Randy Jack
Mark -
Welcome to FTE. You can best sell your stuff thru the CLASSIFIED sections on FTE. You should list them there. I'll bet they go pretty fast, since plenty of 51-52 Guys populate this forum.
