Sponsored by: Auxito
Door lock problem
Old Feb 25, 2005 | 09:09 AM
chaser1602's Avatar
chaser1602
Question Door lock problem
My right side door look quit work with the remote and with the pad on the door It tries to open but cant Is it the motor inside the door or something else?
Old Feb 25, 2005 | 09:11 AM
amish77's Avatar
amish77
how new is it. Those actuators can burn out sometimes.
Old Feb 25, 2005 | 09:31 AM
mel2000f150's Avatar
mel2000f150
I have replaced my pass. side. 2000 f-150
Old Feb 25, 2005 | 10:17 AM
Johns9163's Avatar
Johns9163
Ford is famous for this. You will need to replace the actuator. You may be able to remove the actuator, lube it, and get it free again but the water has gotten into it and it will only last a while longer. This is a common thing. Late 80's / early 90's Mustangs were really bad!!!
