Sponsored by: Real Truck
One tire spinning
Old Feb 25, 2005 | 02:11 AM
shockwave6's Avatar
shockwave6
One tire spinning
How does the front work in 4w, Does only one tire get power?
Old Feb 25, 2005 | 02:49 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Without a limited slip only one tire has to spin on either end.
With open differentials on both ends when two tires spin, one on each axle, you are stuck.
Old Feb 25, 2005 | 10:00 AM
shockwave6's Avatar
shockwave6
I do have LS per axle code. Does this mean that both axles have LS or just one ?
Old Feb 25, 2005 | 10:33 AM
stbrem's Avatar
stbrem
Just the rear. The front is open.
Stephen
Old Feb 25, 2005 | 10:36 AM
etcetera's Avatar
etcetera
The factory LS is almost useless. The L should stand for Lots, as in Lots of Slip.
Eric
Old Feb 25, 2005 | 12:36 PM
BlueZack's Avatar
BlueZack
Is it possible to put in a limited slip on the front without effecting the warranty coverage?
Old Feb 25, 2005 | 03:17 PM
1ruralmailman's Avatar
1ruralmailman
usually not, you have to have some slip for taking corners. oherwise one of two things will give either the tire edges,or the front axle will twist. i know you can put a locking one in but it usually is not the best idea for a truck that lives on pvement,or roads.
Old Feb 25, 2005 | 05:29 PM
etcetera's Avatar
etcetera
I like lockers in the front and back, but something that's manually activated like an ARB. If you need it, you can activate it.
Intalling any LS/locker will void the warranty on the axle. Shouldn't effect anything else though. If you have the work done at a shop or dealer they should cover it for a year anyways.
Eric
