triton 5.8
Old Feb 24, 2005 | 09:16 PM
muddinginfl's Avatar
muddinginfl
Thumbs up triton 5.8
im thinking of putting a 5.8 triton in a 80 truck can i carb this motor if not how much trouble is it to keep the efi on it
Old Feb 24, 2005 | 09:33 PM
stevef100s's Avatar
stevef100s
Never made a Triton 5.8. Maybe a 5.4?
Old Feb 25, 2005 | 03:35 AM
captchas's Avatar
captchas
Guest
5.8 is a old motor also known as a 351 .never was a triton thats a 5.4 . the 5.8 or 351 can be carbed.
Old Feb 26, 2005 | 11:43 AM
muddinginfl
i was wrong on the 5.8 it is a 5.4 can it be carbed
Old Feb 26, 2005 | 03:07 PM
captchas's Avatar
captchas
Guest
i just check my edelbrock catalog and it has no listings other then a tb for our ford mod. motor. since its a 80 truck find a 302 or 351 and start there. you will have tons of choices to make just as i did with my 95 f150. both are good motors and will give you years of fun at a price within reason at todays prices.
Old Feb 26, 2005 | 06:13 PM
stevef100s's Avatar
stevef100s
A carb intake for the 5.4 could be fabricated. The problem lies with the ignition system, without the input from the computer. There is no conventional distributor on the 5.4 engine.
Old Feb 26, 2005 | 06:24 PM
captchas's Avatar
captchas
Guest
where there is a will there is a way, in this case i would go with the 5.0 or .8 and make life much easier on my self. wiring would be a piece of cake motor and trans mounts no problem and a lot of cheap parts every where. esp. mail order,if this your first build up you will learn at a easy pace with a easy job, a computer motor as a first might turn you off to a later swap.
Old Feb 27, 2005 | 04:27 PM
Bart99GT's Avatar
Bart99GT
The only carbureted mod motors I've seen were one off custom everything drag cars. Right around when the 32v 4.6L was introduced in the Cobra in 96 there was an article in MM&FF about someone who had built a carb'd 32v car. I think it had a belt driven distributor w/ remote crank trigger to get around the fact there was never a provision for a distributor in these engines. It had some wow factor, but there are far less expensive ways to make that kind of power so I don't think anyone has bothered duplicating it since.
Old Feb 27, 2005 | 04:48 PM
82F100SWB's Avatar
82F100SWB
Try here:
http://www.modularperformance.com/mi...ategory_Code=I
$600 for just the intake, and it's for a DOHC engine...
I'd suppose that ignition requires crank trigger, or a belt drive mag...
DixieDarlin88
General Automotive Discussion
Apr 29, 2015 10:21 PM
FordGurl83
1997 - 2003 F150
Oct 28, 2014 06:37 AM
gospeedracer
Feb 23, 2011 01:21 PM
Hall382
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Mar 9, 2008 07:41 AM
richsoucie
May 18, 2007 12:59 PM
