Sponsored by: Real Truck
lifters 5.4
Old Feb 28, 2005 | 08:54 AM
wjones's Avatar
wjones
I had A 04 F150 with the same engine and it had a lifter ticking sound for the 2000 miles that I had it. Ford bought it back due to vibration problems. good luck!!
Old Aug 4, 2005 | 06:42 AM
squakilydoo's Avatar
squakilydoo
OK, I'm not sure if this will help or not, but i recently rebuilt my engine in my subaru, and after getting everything put back together, it ticked. I tried everything from replacing the lifters and measuring the came lobes (which were in perfect factory spec), to blowing out the oil channels with compressed air. Nothing worked. finally I had gotten a suggestion to change the seals on my oil pump and it worked. Apparently the seals were bad, and the oil pump was sucking in little bubbles of air which then got pumped into the hydrolic lash adjusters. not sure if that would help on the ford, but thought i would offer
Old Aug 4, 2005 | 07:06 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome squakilydoo, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
