More 368 Questions
Old Feb 24, 2005 | 09:41 AM
01F1504's Avatar
01F1504
Question More 368 Questions
Total YBlock newbie here so please bear with me. I have obtained a 1955 TBird that has a 368 Lincoln motor in it. I have read all the entries in the forum for info on the motor but still need help. Where can I obtain specs and rebuild info as well as listings of any performance parts available for my engine?
Old Feb 24, 2005 | 04:58 PM
312's Avatar
312
there is very little performance wise for the 368.get some info at www.ford-y-block.com.
Old Feb 24, 2005 | 06:16 PM
286merc's Avatar
286merc
The 368 was a strong motor, unfortunately not much aftermarket was developed. 3 and 4 carb 2bbl intakes, 2 4bbls are the most common and show on Epay once in awhile.
Most anyone can grind a cam and internals parts are still available. Lincoln MK11 valve covers look great.
BTW, Im looking for a good 368 to put in a F350 wrecker clone of what I used to work with in 56-8.
Old Feb 25, 2005 | 04:12 PM
01F1504's Avatar
01F1504
Hey, thanks for the replies and the assistance. Looks like I'd better start checking EBay and the swaps for a manifold and carb set up.
Old May 25, 2005 | 05:38 PM
bubba22349's Avatar
bubba22349
Hi 286merc,
I have a running 317 Truck engine that has the ram’s horn exhaust manifolds, truck flywheel, and bell housing, water pump, fan & shroud, pulleys. Etc. If you are looking for some parts for that 56 F350 wrecker clone.
Old Jun 5, 2005 | 10:29 AM
KULTULZ's Avatar
KULTULZ
There was very little available for the 341/368 LINCOLN Y-BLOCK as they were used exclusively in LINCOLN passenger cars until 1957 when MERCURY took the 368 and powered it up to 290HP (4V) for the 1957 MERCURY TURNPIKE CRUISER. There was also an 8V option offered (M-335) (developed by Bill Stroppe) that was rated at 335HP.
For tech information, a 1957 MERCURY SHOP MANUAL would most likely be your best source.
The bell housing pattern is unique also, as the LINC Y came through with the HYDROMATIC 4/S. MERC offered a stick shift version in 1957 but very few were produced so a bell housing may be difficult to find.
Supposedly, a later 302/332HD truck engine 4V intake will fit the earlier passenger car engine (trying to verify now) as it offers a higher carb pad and the increased size carb mounting flange for 4150/4160.
It is an extremely stout engine and worth building.
-The LINCOLN Y-BLOCK-
-The MERCURY MERMAID 368-
-EGGE Obsolete Engine Parts-
WerbyFord
Oct 23, 2023 09:17 AM
01F1504
Nov 30, 2021 05:07 PM
1960fordf350
46
May 2, 2010 05:36 PM
bluesky636
Jan 6, 2009 12:00 PM
hpguy
Mar 29, 2006 07:19 PM
