Beefing up rear helpers on F-350
<!--StartFragment --> I'd like to add two or three leaves to my rear helper springs. Truck squats way too much before the current helper spring even touches. I figure adding some leaves will bring it up closer to the frame and accomplish the goal.
Anybody ever do this?
I was looking at the Edge mini's that are usually used in the front to space the spring up a bit.
Your thoughts are appreciated...
Originally Posted by jeffwoehrle
I'd like to add two or three leaves to my rear helper springs. Truck squats way too much before the current helper spring even touches. I figure adding some leaves will bring it up closer to the frame and accomplish the goal....
Jim
Thanks for the replies...
Not a big fan of Timbrens or air bags. I just want to get the overloads closer to the frame and stiffen that pack a bit. For my purpose that will be ideal.
Local spring shop (not really local, but close enough) told me on the phone to bring the truck in & they can match up two or three leaves to add under the current overloads for about $150 installed. (Includes longer U bolts.)
Spring arch will increase just a tad, which is pretty much what I was looking for.
Single leaf overloads appear to be pretty much a cosmetic upgrade from the factory. Adding a little heft to the overloads will make them far more functional.
Again, thanks for the info.
twinpeaks
02-04-2010 01:20 PM
Mikestrucks
01-30-2006 03:56 PM
GeneStoner
03-27-2003 03:37 PM
