Sponsored by: Real Truck
flowmaster 40, 50, 70, or delta flow
Old Feb 24, 2005 | 12:12 AM
Budkole's Avatar
Budkole
I didnt get much of a response in the other forum so here goes,
Hi Guys and Gals, any input from you will be greatly appreciated.
I have a 2000 ford excursion 4.30,v10 of course.
I tow a lot ,every other day, sometimes as much as 10,000lbs
I want a flowmaster or compairable , not really for performance (stock setup is perfect I havnt had any problems towing ,125,xxx), but just for the sound if it. If it adds performace then that a plus.
Does any body have any experiance with either the flowmaster 40, 50, 70, or delta flow in either verson.
I DONT want to loss torque or hp, maybe gain a little.
looking for something with a good sound that aint too loud inside (annoying)towing 10,000lbs long distances.
I have heard that some mufflers will make you lose torque, I definitely want to stay away from those.
I am changing the muffler only, everything else is stock.
Any help, pleeeeeese.
ps, i did a search already but nobody quite cover the questions i have.
Old Feb 24, 2005 | 01:03 AM
chiahunw's Avatar
chiahunw
Go with 50. 50 is designed for large displacement engine in SUV. 50 is quieter than 40 at idle and normal cruising speed. It will get loud when you put the hammer down.
Old Feb 24, 2005 | 01:32 AM
duckhacker's Avatar
duckhacker
I have the delta 40 and a dump out on my v10. I am happy with it...not too loud but you can tell it is there when you get on it, sounds great.
Old Feb 24, 2005 | 01:36 AM
SMiller's Avatar
SMiller
Running stock exhaust with just a Flowmaster you will have a hard time even telling it has a good muffler, might as well just run a strait pipe. The cat takes all the sound away. If you must have a muffler use the 40 series, but I would just dump the muffler and run a strait pipe, the V-10 exhaust really doesn't get a good mean sound, just more like a indy car. A good free flowing muffler will not take away any power, you might get a hp or two at most, so you will never feel a differnce, it will get a little more heat out of the manifolds and heads, that can only be good.
Old Feb 24, 2005 | 10:26 AM
igotoneforya's Avatar
igotoneforya
I have a Super 40 with 2 pipes leaving the muffler. I welded up the new dual Super 40 in the same location and used the stock pipe for one and added another out the other side to mirror the stock pipe. Cheap to do. Muffler off ebay for 80 and 80 to do the welding and mounting. I absolutely love it. It is close to the sound of a V8 rumble with no negative noise. It is not as loud as I thought it would be, but it is great at start up and on the road. The only thing I do not like is 1400-1500 RPM cruising it has a bit of a drone, but it is not a common cruising speed (50mph) so it does not happen often or for long periods of time.
Old Feb 24, 2005 | 10:51 AM
Outpost22's Avatar
Outpost22
I've got the 50 series beacuse the 40 series sound clip I heard was too loud. If you're towing, the 40 will get to your ears unless you're deaf anyway
The 50 has a slight drone inside the cab, but not near like a 40. Outside sound is o.k. but will never be like a V8. Definitely sounds better than stock. I only replaced the muffler and put on a chrome tip.
Old Feb 24, 2005 | 12:55 PM
camo4stealth's Avatar
camo4stealth
I have a flowmaster 40, with about a 6 inch tailpipe. It's REALLY LOUD. But, I like it that way.
Old Feb 24, 2005 | 12:59 PM
kenneBF250V10's Avatar
kenneBF250V10
I'm running to 30 series FM's with a true dual set up and it sounds real good outside but a little to much interior noise at mid-range rpm's.
Old Feb 24, 2005 | 01:18 PM
Budkole's Avatar
Budkole
Thanks for the input guys.
I definitely dont want a horrible drone while towing
..has anybody heard of any of these mufflers making you lose low end torque
Old Feb 24, 2005 | 10:24 PM
Greg250's Avatar
Greg250
I have a 40 series flowmaster on mine and it is loud. The drone gets annoying when you are road trips. It does a good job of waking up the neighborhood.
