99 Eddie Bauer
Old Feb 23, 2005 | 11:53 PM
lrw174's Avatar
lrw174
99 Eddie Bauer
Where is the Mass AirFlow Sensor located?
Old Feb 24, 2005 | 08:43 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE
…..See you on the boards.
Old Feb 27, 2005 | 09:31 PM
kb-65's Avatar
kb-65
Between the air filter and the throttle plate.
Old Feb 28, 2005 | 05:10 PM
lrw174's Avatar
lrw174
Thanks for the reply I found the sensor and cleaned it but I still have a P0171 and P0174 code problem. Does anyone know how to check the Mass Air Flow sensor to tell if it is bad or not? I have an inline K&N filter however there did not seem to be any oil from the filter on the sensor.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
