overdrives
Old Feb 23, 2005 | 08:07 PM
dlhngrs's Avatar
dlhngrs
overdrives
I am restoring a 1969 F-100. I have a Warner T-18 transmission with a 3.25 rear axle. Does anyone know of a overdrive that can be adapted to this transmission? I am primarily interestd in increasing fuel economy. The truck will not be used for any heavy duty jobs.
Old Feb 24, 2005 | 05:55 AM
jowilker's Avatar
jowilker
Didn't say what engine that you will be using. An overdrive slows the engine speed down while crusing. A cheep way to do that is drop your rear ratio to 3.00 or 2.75 if your engine is big enough to handle it.
If you are running a 302 or 300 I6 later model trannys are available, but not much for the FE.
John
